Originally Posted By: milkboy
To everyone advising PP/PU on a one year OCI, you are a bunch of enablers
That is what I'd like to do, but I feel guilty in the fall if I drop 6 qts of PU, knowing that it's only at a fraction of it's utility.
It really isn't about $30 /yr., it just seems wastefull
Why not just use a good blend? That way you don't feel like a cheapskate by using a conventional but you're not draining 6qts of gently used full syn.
Magnatec 5/30, problem solved.
