Originally Posted By: Ifixyawata
Originally Posted By: ET16
Could you have a vacuum leak?
I probably could but I think it would present itself at idle or as an idle problem rather than just an under load problem. Would a vacuum leak be able to create a situation that would throw a misfire code like I had last time?
If a vacuum leak is large enough, air bypasses the MAF, then creates all kinds of different problems. Normally you would get a MAF code or a lean mixture code, but vacuum leaks can cause a variety of problems.
1. Has the PCV valve been replaced?
2. Is that PCV valve an OEM part?
When a PCV valve becomes old, the spring inside it can develop metal fatigue, and let extra vacuum into the engine when it isn't supposed to. Afermarket PCV valves either have springs that fail too quickly, or they never were calibrated to function exactly like the OEM PCV valve.
It doesn't help that some Fords have really awful vacuum hoses.
