I'd like to get a discussion started on turbochargers. I've recently become more interested in them since I bought my new 2016 WRX, and, naturally, have found myself thinking about turbochargers more.
I feel like I have a pretty good baseline understanding of how turbine systems work, as I've long had a strong interest in aviation and have spent some time studying the operation of gas turbines. So, I'm looking more for detail in turbo operation.
As stated in the subject, my questions relate to the bearings and cooling, and just wanting to learn more about the operation of turbochargers in general - how to optimize their life, etc.
So, I've read that my 2016 WRX uses a Honeywell (Garrett) GT2259S:
https://www.turbobygarrett.com/turbobygarrett/turbocharger#GT2259
From the description, apparently it's oil-cooled only. I was wondering what kind of bearings it uses. On Garrett's page, the boxes for both ball-bearing AND journal bearings are checked...so, which is it? Does it use both types of bearings?
Would it be correct to say that "journal" bearings are hydrodynamic in operation, like the crankshaft main bearings and connecting rod bearings in an engine?
I remember reading, about 20 years ago, when I started getting interested in engines and performance cars, that it was a bad idea to immediately shut a turbocharged engine down, especially after highway driving or driving under load, due to the possibility of coking in the turbocharger due to oil sitting in the unit and getting cooked. Therefore many people would run turbo timers - basically a timer on the ignition to allow the engine to idle for a pre-determined period after the key was removed in order to allow oil and/or coolant to continue to flow through the bearings for a while with the engine at idle, in order to allow temps in the bearings to drop, hopefully enough that coking wouldn't occur.
Is coking still a problem with modern turbos and oils, or has the design of modern turbos and materials/specs used mostly accounted for that problem?
I know some turbocharged vehicles have water-cooled turbos (the new Fords?) and also have small electric pumps that continue to circulate some coolant through the turbo housing after engine shutdown... Obviously my Subaru, having an oil-cooled (only) turbo, doesn't have that feature, so I've been trying to let it idle for a couple of minutes after shutdown, to hopefully allow temps in the turbo to drop a bit.
After draining the FF, I plan on using PP 10W-30 due to very good NOACK (4.7%) and hopefully a bit less tendency to shear, though I know that'll happen with this engine, as well as being diluted with fuel (direct fuel injection).
