My old (as in pre 1983) Fiat's called for an "unusual weight" from the factory, 15W40. Well maybe for a gasoline engine but seems like most diesels use this grade.
I've always used 10W30 but started using the Shell Rotella 15W40 thinking it might have some benefit when using a turbo (since most diesels are turbocharged).
I never installed an oil cooler on my Yugo when I turbocharged it about 10 years ago. I did run one on my Fiat 124 Spider for years. When I decided to build a custom A/C system for it back in 2010, the condenser went where the oil cooler was located.
It's hard to tell how many miles are on each of these engines. The Spider's engine was rebuilt back in 1992. The Yugo's 1500cc engine came out of a 79/80 Fiat X 1/9 with unknown mileage.
Just curious if an oil cooler is really nessessary. I've yet to "rig up" a temperature sensor in the oil pan to see how hot the oil is getting but I did aim one of those thermal heat pens after I pulled into my garage and I don't think the oil any more hotter than the engine (~200F). Seems to me I read oil starts breaking down above 250F.
These cars are not raced, just street toys. So it's not like the engines are constantly pushed to their limit.
