Hi
Currently running the 5w-40 Penrite Diesel 5 (see product data below) in my Holden 3800 V6 engine (petrol) the exhaust appears to be slightly darker in black deposits than when I was running the 5w-40 Penrite Everyday semi-syn.
The fuel I use is the premium, 98 Ron, unleaded it has 50ppm max. There has been no change in driving habits since the oil change. City driving 50% fwy and suburban driving.
Is darkening of the exhaust tail pipe deposits typical when you switch to a mixed fleet oil for petrol and light diesel ?
Penrite Diesel 5
Industry Specifications
API CI-4 PLUS/SL
ACEA A3/B4/E7
Global DLD-2/DLD-3
JASO DH-1
JASO MA
Manufacturer Specifications
MB 228.3/229.3 VW 502.00/505.00 Opel B040 2098
Ford M2C153-H/171-C/913-B/913-C Peugeot PSA D-02
Typical Data
Density at 15°C, kg/L 0.859
Viscosity, Kinematic, cSt
at 40°C 100
at 100°C 14.7
Viscosity Index 152
Cold Cranking Viscosity, cP at -30°C 5,576
Zinc, Mass % 0.122
Phosphorus, Mass % 0.110
Sulphated Ash, mass % 1.34
Base Number 10.7
Penrite Diesel 5
API CI-4 PLUS/SL
ACEA A3/B4/E7
Global DLD-2/DLD-3
JASO DH-1
JASO MA
Typical Data
at 40°C 100
at 100°C 14.7
Viscosity Index 152
Zinc, Mass % 0.122
Base Number 10.7
