Originally Posted By: supton
Originally Posted By: Garak
They want to drive the snot out of the vehicle in their tests, have a 20,000 mile OCI, and be able to use the cheapest oil they can find.
isn't that what most consumers want? Including BITOG'ers?
I agree. I remember reading about a new engine a few years ago, I won't mention the name to avoid starting a battle here. They claimed 40,000 hours of testing went into the design. After release they had some problems. I got to thinking how many engines did they test for 40,000 hours? Or did they test 40 engines for 1,000 hours, that also totals 40,000 hours of testing. They weren't too specific. The bottom line is the long term testing is done by the consumers, and many times they get screwed. I'm certain C&D can't come close to testing like a mfg would, and even the mfg's testing often falls short.
Ever read up on the venerated Slant Six? Chrysler did all sorts of testing and as a publicity stunt ran a fleet of NYC taxi cabs to show off the new engine. On the very first day of this stunt every single car had to be towed off the street. All of 'em. Turns out, there was a problem where the rings fluttered at idle, and the plugs oil fouled. All that testing, and apparently no testing done at idle. But as we all know that turned into a very reliable motor.
Still wouldn't have wanted to be the guy buying the first one off the line only to find out that the rings needed replacing in short order!
Jaguar ran into a sort of similar problem with one of its engines. Through hard testing, the combustion chambers always stayed clean, but under softer street driving, the engines would accumulate carbon, and then blow upon release of this carbon when the engine finally was driven harder. They never found out during testing.
