Originally Posted By: badtlc
Originally Posted By: FetchFar
Originally Posted By: Miller88
I have got 30MPG out of my parents 2.0 Ecoboost Ford. The key is to ALWAYS let it draw a vacuum. As soon as it starts building boost, it starts running pig rich.
I use the sport mode and as soon as a slight hill comes along, I make it shift to 5th or 4th gear. Then it's fine. When it's lugging along trying to pull a hill at 1500RPM in 6th gear, it is running super super rich to avoid pinging - it's pussing 7 or 8 pounds of boost. If I drop it to 5 or 4 to pull the same hill, it's running at much lower boost PSI and not running as rich.
It can't run rich, since emissions laws (engine control software) prevent that. It can retard timing a bit to prevent detonation (pinging). Ecoboost also relies on the direct injection cooling the mixture to avoid detonation as well during lugging with high boost.
What are you talking about? Modern cars have to run rich to meet emissions requirements. You are starting to wander off the reservation with your posts.
Honda Civics had a high fuel econonmy model in the mid 90s that was capable of mid 50s US MPG on the highway. Lean burn model. Was shot down because it was polluting too much by running lean and using such a small amount of fuel.
The same with DFPE "regen" cycles.
