2011 Ford Mustang 5.0L V8 Ti-VCT 32-valve
Pennzoil Ultra 5w20 SN/GF5
Motorcraft oil filter FL500S
Motorcraft air filter FA1897
Code:
MI/HR on Oil 10,377 10,129 9,995 UNIT / UNIVERSAL
MI/HR on Unit 59,590 49,213 39,083 LOCATION AVERAGES
Sample Date 04/21/14 09/03/13 01/26/13 AVERAGES
Make Up Oil Added 1.6 qts 1.2 qts 2 qts
ELEMENTS
ALUMINUM 3 4 4 4 5
CHROMIUM 1 0 0 0 0
IRON 13 12 11 12 22
COPPER 2 2 3 2 5
LEAD 0 0 0 0 1
TIN 1 0 0 0 1
MOLYBDENUM 56 60 60 59 71
NICKEL 1 0 0 0 1
MANGANESE 3 3 3 3 5
SILVER 0 0 0 0 0
TITANIUM 2 2 2 2 1
POTASSIUM 1 2 0 1 4
BORON 54 51 89 65 87
SILICON 6 6 7 6 12
SODIUM 4 4 4 4 53
CALCIUM 2380 2600 2644 2541 2065
MAGNESIUM 36 37 12 28 287
PHOSPHORUS 700 692 755 716 779
ZINC 829 787 870 829 852
BARIUM 0 0 0 0 1
PROPERTIES
cSt Viscosity @ 100°C 55.1 54.2 52.9
SUS Viscosity @ 210°F 8.8 8.53 8.16
Flashpoint in °F 430 415 415
Fuel %
Antifreeze % 0.0 0.0 0.0
Water % 0.0 0.0 0.0
Insolubles % 0.3 0.2 0.2
TBN 2.3
Blackstone's COMMENTS:
If you look up "steady" in the dictionary, there just might be a picture of these wear trends. It really doesn't get much steadier than this. Iron has fluctuated by only 2 ppm over three samples -- that's remarkable. Other metals are even steadier, though we do expect them to be a little steadier than iron (iron has a tendency to change a little more than other metals, depending on operational conditions). The TBN read 2.3, which is fine since 1.0 or less is low. This oil could see more use, if you wanted. It's holding up well. No problems here, at all! Nice trends!
Code:
ELEMENTS
ALUMINUM 3 4 4 4 5
CHROMIUM 1 0 0 0 0
IRON 13 12 11 12 22
COPPER 2 2 3 2 5
LEAD 0 0 0 0 1
TIN 1 0 0 0 1
NICKEL 1 0 0 0 1
MANGANESE 3 3 3 3 5
SILVER 0 0 0 0 0
TITANIUM 2 2 2 2 1
POTASSIUM 1 2 0 1 4
SILICON 6 6 7 6 12
SODIUM 4 4 4 4 53
BARIUM 0 0 0 0 1
PROPERTIES
Fuel %
Water % 0.0 0.0 0.0
TBN 2.3
