Planned on changing it at 12K but at 11K I was presented the opportunity for a long road trip so I figured I would go for it. Seems to have turned out OK.
Note: toward the end of my last OCI I thought I noticed a bit of start-up noise and the oil light staying on a little longer than just a flash. Figured it was my mind playing tricks on me because it was almost time to change plus I was debating leaving the filter for another interval per the manual. I left the filter and in less than 400 miles I was back under there swapping it out; it was not my mind playing tricks on me. I believe the ADBV weakened or failed so I was getting dry starts after it sat overnight. Perhaps these dry starts added a bit of wear and my next report will be better.
Regarding the silicon: yes it is on the high side of OK but it seems to be in line with other civics.
Enjoy!
Code:
LAB NAPA/WIX
MAKE HONDA
MODEL CIVIC LX
ENGINE 1.7 SOHC
YEAR 2005
OIL TROP ARTIC TROP ARTIC
WEIGHT 5W-20 5W-20
MILES IN USE 14,102 10,017
MILES 158,278 144,176
SAMPLE TAKEN 01/11/2014 06/22/2013
FILTER PUREONE PUREONE
IRON 11 7
CHROMIUM
LEAD 3 3
COPPER 11 3
TIN 2
ALUMINUM 5 4
NICKEL
SILVER
TITANIUM
VANADIUM
SILICON 22 16
SODIUM 17 5
POTASSIUM 6
WATER
COOLANT NO NO
MAGNESIUM 1 8
CALCIUM 2313 2199
BARIUM
PHOSPHORUS 699 633
ZINC 862 736
MOLYBDENUM 81 64
BORON 32 52
SUS VIS 210ºF 8.9 8.4
TBN 1.7
TAN 3.43
Previous Post:
http://www.bobistheoilguy.com/forums/ubb...les#Post3133903
Enjoy!
Code:
LAB NAPA/WIX
MAKE HONDA
MODEL CIVIC LX
ENGINE 1.7 SOHC
YEAR 2005
WEIGHT 5W-20 5W-20
IRON 11 7
CHROMIUM
LEAD 3 3
COPPER 11 3
TIN 2
ALUMINUM 5 4
NICKEL
SILVER
TITANIUM
VANADIUM
SILICON 22 16
SODIUM 17 5
POTASSIUM 6
WATER
COOLANT NO NO
MAGNESIUM 1 8
CALCIUM 2313 2199
BARIUM
PHOSPHORUS 699 633
ZINC 862 736
MOLYBDENUM 81 64
BORON 32 52
TBN 1.7
TAN 3.43
Previous Post:
