I own a 2001 Land Rover Discovery II with a 2.5 Turbo Diesel engine.
While checking on the gearbox manufacture site ZF TE-ML 11 ZF model 4HP22 (page 3) they claim I must use a 11A/B oil from the list.
One of the options is the ZF-Lifguard5 ZF-Lifeguardfluid 5
The ZF LifeGuard 5 is:
Automatic gearbox 4HP22 ZF-Lifeguardfluid 5
Charakteristics TE-ML 11B
Density at 15 °C kg/m³ 0.85
Viskosity at 40 °C mm²/s 38
Viskosity at 100 °C mm²/s NONE
Viskosity index NONE
Brookfield-Viskosity at -40 °C mPa.s NONE
Pourpoint °C -51
Flash Point(COC) °C 220
While the Shell Spirax S6 ATF ZM is:
Charakteristics TE-ML 04D 14E
Density at 15 °C kg/m³ 0.843
Viskosity at 40 °C mm²/s 61.8
Viskosity at 100 °C mm²/s 10.2
Viskosity index 153
Pourpoint °C -53
Flash Point(COC) °C 240
the Shell Spirax S6 ATF ZM is an equivalent to ZF's ZF Ecofluid A Plus Ecofluid A Plus
Here are ZF 11B 14E 11b and 14E characteristics
Can i use a TE-ML 14E oil ? like Shell Spirax S6 ATF ZM ?
Pourpoint °C -51
Viskosity index 153
Pourpoint °C -53
