Originally Posted By: ZeeOSix
Originally Posted By: MrMeeks
I've seen this. Caused by a manufacturing flaw where glue runs onto the adbv and bonds the valve to the base plate.This prevents oil from entering the filter.
But the OP said they just loosened the filter to let it bleed and then re-tightened it and all seemed well then, so if it was a stuck ADBV, I don't see how that would cure the problem.
Filter was never fully removed and replaced ... if so, then it would have been interesting to cut it open for a look.
Yes - this does not make sense as an explanation. That would be a VERY distrubing pathway for glue to work it's way around the ADBV and seal to the base plate, and yet not get to other places. Also, to seal the ADBV closed, that would mean the seal had to resist perhaps 100psid as the pump pushed oil, slammed into a glued ADBV, and then relieved the oil at the pump bypass ... I don't buy it. Especially after "burping" the air out (filter off, then back on) made the problem go away.
These filters have very high bypass settings; Wix is at 16 psid, Fram is at 22 psid, and Purolator is at 25-35 psid! This things expect HIGH pressure to open the internal bypass.
My first suspicion would be the pump lost prime and it's not the filter at fault.
Filters don't prime themselves, but pumps do. If the filter didn't get oil, it's not the filter's fault ... you have to start at the source. Filters don't suck oil into themselves; they receive oil from a pressure source. No oil in the filter? Look upstream!
