Originally Posted By: tig1
Originally Posted By: DrDusty86
TIG calm down,
there are 50 different oils on the market that would make the filler hole just as clean.
You always tout your pictures. THEY MEAN NOTHING TO ME! I could use Supertech and produce similar results. You spend to much on oil.
Some of the latest amsoil data shows Castrol GTX better than M1 in catagories. Is Amsoil lying? Are they tests not factual?
I don't know how to link or I would post it.
If you will notice(again you are not reading my post)I never critize another product. I only report on what I have used. You really need to be more factual.
Dusty. The application is a huge part of how an oil performs.
For example Toyota relishes their mpg's,so they custom tailored an oil that has a high viscosity index and high in friction modifiers so the engines have as little drag at start up as possible which can have a significant effect on how the EPA tests and rates fuel consumption. An oil with a lower viscosity index and less moly will consume more fuel at start up until the oil has reached operating temp,at that point the ht/hs value has more bearing on pumping resistance.
And just because you choose to ignore tigs pics doesn't mean someone else won't find value in them. His opinion is just as important as yours and he doesn't feel the need to capitalze(yell) when posting his opinion.
Now dusty I may just agree with your views on Mobil 1 products however any recommendation a member makes in a thread should stand on its own,and not screamed from the rooftops,especially if you,or I,don't agree.
I mirror your feelings as far as most Mobil products go however I don't feel the need to take tig to task based on my differing opinion. He's had fantastic results using M1 and his pics deserve every bit as much attention as anyone else's do.
I'm not trying to fight with you dusty,I just don't like how you are treating tig. Its uncalled for,he has every right to posts his experiences,just as you or I,and I don't think he should be treated in this manner based on a differing of opinion.
And tig. Your experience with Mobil products is likely second to none on this site. You have been brand loyal for decades and your posts reflect your extensive knowledge using M1 lubricants,so don't let anyone get to you.
Your opinion is as valuable as anyone else's so don't allow anyone's bias,including mine,to affect whatever you choose to post.
TIG calm down,
