JHZR2
Staff member
We have a fluorescent light over our washing machine and dryer. It plugs into an outlet and uses the standard size fluorescent tubes. 40 W T 12 I believe. Based upon my understanding it is acceptable to run T12 bulbs in these new style electronic ballast lights. Our old one failed but the tubes were perfectly fine so I reused them.
When I start up the light it works perfectly fine, bright light no issues. But if we leave it on for a long time it starts to flicker with a 60 Hz type flashing. It doesn't turn off or go dark, it just loses intensity to look like a flicker at a very rapid rate.
The odd thing is that if I turn it off via the pull chain and then start it back up again it will not turn back on. I have to unplug the light and then plug it back in, at which point it starts up and puts out perfect light again without any flickering.
My understanding is that T12 bulbs are acceptable for use in the new fixtures. However I believe that the T12 bulbs are 40 W while the T8 bulbs and 32 W. The ballast in the light definitely feels warm to the touch, but I can't say that it is excessive. The flickering occurs only after being on for a long duration.
Any thoughts on the cause of this??
Thanks!
Thanks!
