Originally Posted By: 4x4chevydude
is there a reason they dont reccomnend it, I like to keep up with clean lines and injectors in my vehicles before they get clogged or cause midfire codes....I didnt realize GM did not reccomned the MMO though
The fact is that as long as you are in the USA, you will almost never have an issue with contaminated gasoline. The lines don't get dirty, and the injectors will be fine since your fuel is first being filtered long before it reaches the injectors.
The most likely issue would be carbon build up on the injector pintle which could possible keep the nozzle from spraying evenly or possibly sticking open causing a leak.
Even this is pretty rare today because most gas has ethanol and other detergents that do a very effective job at keeping these clean.
If you want just occasionally use a bottle of PEA detergent cleaner like Redline, or Techron. The full strength versions will remove any build up from those parts and the combusion chamber+valves.
MMO is an oil, and has NO place in a modern fuel system, if anything it will create a dirty build up situation.
Anything that claims to be a fuel system lubricant should be avoided at all costs, they do more harm than good as today's systems are designed with modern fuel characteristics in mind, no need for some so called additional lubricant.
