Originally Posted By: rrounds
The S2000 has a larger oil filter than all the other Honda's of those years(1999 to 2009).
I run a Baldwin filter that is over twice as large as the big Honda oil filter for the S2000. I change it every other oil change, works for me.
You also stay out of bypass more with a larger oil filter and I like the oil getting to my engine to go through the filter not around it.
ROD
May I ask which Baldwin filter you used?
ROD
