quote:
Originally posted by robnitro:
Also, since the bottle itself said to shake it before putting it in, I bet the metals weren't fully miscible. So they will settle out of oil probably, which means they aren't as integral to the oil, like a ZDDP or moly additive. It seems like how PTFE would act in an oil, but without the issues of PTFE.
I think it sticks to metal easier than the metallic oil additives would (like ZDDP, moly) because it may not need as much heat to plate up, but its more like spreading warm butter over bread, where it fills up the little holes in the bread. I think that is what makes it not last too long though, because its not really chemically bonded to the metal, it's more like temporary that scrapes off eventually, returning compression back to previous levels?
