Has anyone used it with good results? I got a bunch of quarts from AAP for about $4 ea. I'd be using it for some drain and fills on a 2006 Ford Fusion V6. It has the Aisin 6-speed auto and about 92k miles.
Castrol says it's good to go for that transmission, although they don't mention the exact Ford spec. They do cite the Toyota T-IV spec, which I believe is the same. T-IV is even stamped on the dipstick. Ha. The Motorcraft ATF Is rather expensive at my local stealership and the Mobil 3309 isn't available locally and is pricy to order and ship.
