round these parts FRAM is on the ,"NOT a chance in [censored] to use ", they are not the filter once made. Look carefully ... Motorcraft i believe is made by Champion filter, correct me if i am wrong, might have changed, i hear good things about this filter, WIX is made by DAna and is good, also Check out the Napa gold line,Baldwin, Amsoil is also good, listen to your start up noise when you change it, a good filter will usually not have none to little engine noise . Have Fun,
