Question about oil used a Harley-Davidson V-Rod engine, it's a single sump set up. H-D book calls for 20-50 unless temp is below 40, the 10-40.
Why is 10-40 only ok when the starting temp is below 40? I understand the 10 weight oil flows better at lower temps, but with synthetic does it matter? How much better does a 10 weight synthetic oil flow compared to 20 weight synthetic? Once the engine is warmed up to operating temp and running on the highway, does 10-40 offer less protection then a 20-50? I would like to know, I'm a 365 rider, as long as there is no snow or ice on the road I ride to work. Winter time morning temps can be down in the upper teens and low 20's.
On my non H-D bikes I run a motor cycle rated synthetic oil 5w-40. Would this oil cause problems to a V-Rod's engine if used during the summer?
