2009 Honda Fit Sport, 28,600 miles (IIRC) on the car with the oil change. Blackstone said to run out to 11k miles and sample again. Fuel is a bit high because we jockeyed the car around a little in the driveway prior to the oil change. The silicon tells me that OEM Honda air filters are just fine. Car is on its second Honda air filter. Oil filter was a M1-104 (crosses to Purolator L14459). I put in more M1 0w-20 and another M1-104. Hope to re-sample at 15% on the OLM.
Report:
Code:
MI/HR on Oil 8,800
UNIT /
MI/HR on Unit
LOCATION
Sample Date 10/29/10 AVERAGES
Make Up Oil Added 0 qts
ALUMINUM 5 5
CHROMIUM 0 0
IRON 13 13
COPPER 3 3
LEAD 0 0
TIN 0 0
MOLYBDENUM 85 85
NICKEL 0 0
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 4 4
BORON 44 44
SILICON 9 9
SODIUM 6 6
CALCIUM 2028 2028
MAGNESIUM 10 10
PHOSPHORUS 562 562
ZINC 654 654
BARIUM 0 0
Values
Should Be*
SUS Viscosity @ 210°F 48.7 46-56
cSt Viscosity @ 100°C 6.88 6.0-9.4
Flashpoint in °F 340 >385
Fuel % 2.3
Antifreeze % 0.0 0.0
Water % 0.0
Insolubles % 0.4 pre>
Report:
Code:
MI/HR on Oil 8,800
UNIT /
MI/HR on Unit
LOCATION
ALUMINUM 5 5
CHROMIUM 0 0
IRON 13 13
COPPER 3 3
LEAD 0 0
TIN 0 0
MOLYBDENUM 85 85
NICKEL 0 0
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 4 4
BORON 44 44
SILICON 9 9
SODIUM 6 6
CALCIUM 2028 2028
MAGNESIUM 10 10
PHOSPHORUS 562 562
ZINC 654 654
BARIUM 0 0
Values
Should Be*
Fuel % 2.3
Water % 0.0
