Not sure if this was hammered to death on here before but it's new to me....
I was out with my parents in their 2007 Lexus RX350 when the fan belt started squeling. Then the A/C kicked off and I could smell oil.
We pulled over and lefted the hood but with all that plastic engine covering we couldn't see anything so I went under the car and oil was running all over the bottom and again with all the plastic coverings I wasn't able to see anything.
Luckly the vehicle comes with a small tool kit and I removed the plastic coverings top and bottom and discovered that the rubber hose on the metal oil feed line that feeds the VViT system on the rear cylinders had a pin hole in it and was spraying oil out and so much had leacked that there was even a fine mist of oil all over the back window. Long story short I added 5 quarts of oil and we drove as close to home as we could but everyone that drove past us was yelling about the smoke coming out of the hood! We pulled over again and opened the hood and smoke just billowed up and out so we checked the oil level again and all 5 quarts was gone. We just called a tow truck and had it towed home and I started to remove the line but it turned out to be a huge ordel.
Called Lexus and they are paying for everything even though we bought the car used and it's out of warranty. The loaner they gave my parents was a 2010 RX and the rubber line is no longer on these engines. it is now all metal the way it should have been all along.
