Greetings,
I have a 2002 Toyota Tacoma with the 2.7L 4-cylinder (3RZ motor) with 123,000+ miles. I just performed a valve adjustment on it following the Toyota FSM and replaced 7 shims. Only 2 valves were out of spec (and only slightly) and the other 4 were just on the bottom end of range. Following the adjustment all 16 are now right in the middle of the correct specifications.
I did the adjustment because it's recommended every 60,000 miles and I don't know if it had ever been done. In addition the 3RZ is known to burn valves when the exhaust valves get to far out of spec, which is because as the valve clearance gets to low, the valves don't fully seat which allows them to get too hot. Anyway, following the valve adjustment I performed a compression test just to be sure everything was good. I got 165psi/130/165/175. You can imagine my dissapointment... However, upon adding a little oil to cylinder 2 and testing it again I got almost 160psi, which points to worn rings/cylinder walls, not a valve issue.
The truck runs/idles/drives perfect and uses ZERO oil between changes. I had been running Castrol 5W-30 but last oil change I switched to Valvoline Synthetic 5W-30. Now I'm debating switching back to a High MIleage oil like Castrol High Mileage or Valvoline Max Life synthetic blend because I'm concerned about blowby.
I not going to do anything about the engine as tearing it apart would cost more than I could find a good low mileage used engine. Besides, it could last another 50,000 miles like this.
So should I go for a High mileage oil and if so which one? Should I go up to 10W-30? Or should I just stick with what I've got?
Thanks in advance...
