My buddy has this truck, and it started having this weird issue where when you pull to a stop sign, the oil pressure goes to 0, then pops up moments later. This always happens only at the end of the oil change which was M1 5w30 at 7500 miles. This started two years ago. Well he just started doing shorter oil changes at 6k miles and issue appeared to be gone. Last year he changed over and started to use PP at 6k changes. We were just outside looking at some of the performance parts he put on it and just for the heck of it, maybe bitog ocd, i pulled the dipstick and there was black very thick goo on the dipstick. Looked like heavy gear oil that was cold. Not sticky like tar, but just very thick and black. I asked him how many miles were on this change and he said about 1500. My first thought is maybe the pcv was clogged and causing it. We did find a vacuum leak, but it wasnt on the pcv it was on the port to the left of it. Anyway we pulled the pcv and it dont appear clogged, it was dirty, but i couldnt blow thru it and could suck thru it. We got a new one and put it on there anyway. The truck has about 80k on it and probably dont get driven more than 5 k miles a year now becuae he bought a little beater car to drive to and from work. Anyway, what would you all recommend being he was already using synthetics, M1 and PP. I dont know much about dodge engines but i do know that there are alot of sludge issues with the 4.7s and 5.9s. Truck runs great and were tryign to avoid harsh chemicals. My thought was continue to run PP and just change it out at 2k miles for a while and see if it gets better. Or maybe got to rotella 15w40 and a small dose of MMO. Any thoughts guys. Could this jsut be years of changing oil at too long of intervals.
