A lot easier on motor oil?
Easier than stop and go driving. I would think that the absolute easiest driving in regards to motor oil would be maybe 30-35 MPH without stopping along a flat road. That would also provide optimal fuel economy.quote:
Easier than stop and go driving. I would think that the absolute easiest driving in regards to motor oil would be maybe 30-35 MPH without stopping along a flat road. That would also provide optimal fuel economy. [/QB][/QUOTE]Good point. I notice if I run really hard on the freeway my oil pressure will drop some (assume the oil is running hotter) and then I get on the surface streets and it recovers. Freeway at 60 mph is probably very easy on the oil as is a nice 30-35 mph cruise along a parkway. Another thing that gets the oil hot is rpms. I can lower the oil pressure a bit just by locking out overdrive on the freeway in my motorhome and the oil will get hotter (more friction with faster moving piston at 3000 rpm vs 2400 rpm in OD). Freeway with a strong headwind will do it too.quote:
Depending on the vehicle, optimal fuel economy usually comes somewhere between 50 and 65 mph. That's the ONLY reason we had the 55 mph speed limit back in the day.quote:
I know it's easy on the oil, but I've heard from some sources that freeway speeds aren't necessarily optimal for fuel economy because wind and rolling resistance are higher. The 55 MPH speed limit was supposed to be a compromise. We're probably splitting hairs though, since the most important thing for achieving high fuel economy is not stopping and releasing energy into the brakes.quote:
Just driving along a flat road at 55 mph would be very, very easy on the oil!
Yes, that's true, I was talking more on the lines of the 1 hr commute some people have driving 15 miles in bumper to bumper traffic, where the oil temp gets up to temp, as opposed to my 1 hr commute @ 60mph the whole way. Short trip vehicles are a totaly different thing than either one of these IMO.quote:
Probably not for short trips though. Some people with oil temp gauges have noted that short trip stop & go doesn't get the oil up to full coolant temps, but a longish highway drive will. The hardest thing about short trips will be condensation, while the stop & go will shear the oil.quote:
Originally posted by blupupher:
I would think that with stop and go traffic, oil would get heated up more than constant highway driving. Greater heat = less oil life.
Bob, good to see you!
Are you sure about that? I've always heard that they do that so they don't stall the car, due to the "hair-trigger" race clutches they use which are tricky/impossible to modulate like the clutch on a street-driven car.quote:
Originally posted by BOBISTHEOILGUY:
that is why you see proffesional racers race up the motors before taking off the race line. They are building up the lubrication between the bearing and the piston before dumping the clutch.
If the idea is that if you're getting city fuel mileage, you should use a severe service interval, and if you're getting highway fuel mileage, you should use a normal service interval..quote:
Originally posted by John_E:
Perhaps one should schedule oil changes according to total fuel consumed, which would automoatically result in a shorter OCI for city driving, copious idling or cold starts, etc.
I dont think the racers are thinking about lubrication when they rev the motor to take off...in drag racing the objective is to "shock" the tires...they want a sudden application of power, not a slow gradual buildup...the car is going to move when they "dump the clutch" in either scenario, but that engine making a ton more HP at high rpm than near idle. Most Pro Stock drag cars, at least used to be when i was involved, have a basically two rev limiters...one for burn outs, to heat the tires, and another, set at a higher rpm, for the actual launch...so in effect, for consistency, they just floor it...the rev limiter holding the engine at whatever rpm they want to launch at...quote:
just so you know why hyw is easier on oil.
as your going 55-70 mhp, you have full hydrodynamic lubrication, so in a since, you have oil all around your bearings. where as, when your doing stop and go, you only get partial amount of oil on your bearings so when you start to stop, you tend to squeeze out the oil between your bearing and the piston and cause more wear. that is why you see proffesional racers race up the motors before taking off the race line. They are building up the lubrication between the bearing and the piston before dumping the clutch.
so hwy is much easier on oil verses stop and go. It doesn't shear the oil on the hwy, where it does in town stop and go. the effects of oil shearing . this site will explain what I'm saying.
