Engine is in and running good. Need some ideas for oil.
355 LT1 in a 96 Impala.
Forged bottom end.
Bearing clearances are .002 and .0025.
Cant remember the exact piston to wall clearance. Was set up on the loose side of piston spec for 150-200 shot of the giggle gas.
Rings were filed on the high side.
Hydraulic Roller with just under .6" of lift.
Redline will be in the 6500 range.
Have not done an oil analysis yet, but fuel dilution seems to be not a problem, cant smell it or the oil does not look bad when changed.
I have been reading about the Shell Rotella T 15/40 being speced for a lot of the gas engines.
Car is not a daily driver. Driven to work 2-3 times a month.
Driven around town, to the track and raced.
Dont have an oil temp, but have the stock oil cooler in the radiator.
Edit: Forgot to add. The temp where I live does not get below freezing that often. Most of the time in the winter the car will not be started or driven below freezing.
I am a maint. freak, so 5000 miles will not happen. Usually the way I treat the car, it sees about 3 months, which is no more than 2000 miles.
Thanks.
Forged bottom end.
Thanks.
