Originally Posted By: digitalSniperX1
Isn't he looking for something to stop his minor oil leak? Are the high mileage oils capable of doing that?
Since the LS1 in Corvettes (same engine as in his Firebird) recommend M-1 5W-30, I'm betting he's been using it. Although you don't get the M-1 oil fill cap in the LSI equipped camaro and firebird models, lol.
I'm fairly sure Patman knows one heckuva lot about these engines, hopefully he'll chime in on this one (I've seen him on the LS1 sites).
If I had to choose a conventional oil to run in a higher mileage LS1 Camaro or Firebird, I'd probably go with GTX 10w40 actually. I think the Maxlife 10w40 might just be a tad too thick.
At the same time though, I prefer to recommend synthetics for the LS1, even in the Camaro/Firebird which doesn't call for it. The LS1 in those cars still runs just as high oil temps as the Corvette, and has no oil cooler, so you're safer running a synthetic oil if you drive the car hard in the hot summer for long periods of time. In fact, even if you don't drive it hard, you'll see 240-250F oil temps on a 90 degree day if you're stuck in traffic with the AC on.
I still believe GC 0w30 to be one of the best oils for the LS1, even though I'm using Pennzoil Platinum 5w30 (which is also very good, but just hasn't quite shown as low engine wear as GC did in my engine)
