Interestingly, the new Bandit 1250 manual says to use 10W40, 15W40, or 15W50 API classification SF/SG or SH/SJ and make sure it doesn't have the energy concerving label.....OR it recommends a JASO MA oil of the same weights...
Well, API SL or SM is on all the shelves and these oils say that SL can be used where SF/SG and SH/SJ are required. And 10W40 oils aren't energy concerving...So according to suzuki's own manual a 10W40 car oil off the shelf of Walmart would be just fine since those oils can be used where SH/SJ are required and that's what is required by the manual...At least that's how it looks to me....I wonder if the SM rating meets or exceeds SF/SG and SH/SJ then why doesn't the manual just go ahead and state to use SL/SM as long as it's non energy concerving. Perhaps there is a difference in phos/zinc levels in the SL/SM rated 10W40 automotive applications (except perhaps the diesel oils).
I'm still a bit concerned about phos and zinc levels in a regular car oil like the SM rated Castrol GTX 10W40 compared to a GN4, Suzuki 4T, Castrol 4t, valvoline, or a pennzoil motorcycle oil...I wonder if these 10W40 NON energy concerving car oils have comparable additive levels to the dino MC specific oils..
