I am building a Thatcher CX4 powered by VW conversion. The 1915CC engine will be used with improved heads, low compression for auto gas, forged crankshaft, and oil drain to be every 25 hours. The supplier recommends 30W or 10W30 automotive oil for break-in and normal operation. Other VW builders also use 10W40 & 20W50 automotive oils. I am not aware of synthetic being used for this type of application. The engine will not be assembled until ready for test flights.
I plan to use unleaded auto fuel most of the time with occasional 100LL use. I live in southern NC and fly with temps from 30F to 95F. My flying time will be about 100 hours per year.
Just wanted to hear suggestions about oils to use. I have been considering Rotella T 15W40 (used in my motorcycle & pickup) and aircraft oil. You can use the link to my website in my profile section that gives more info about the CX4.
Thanks,
Thanks,
