I have a two zone HVAC system. Each floor has its own zone controlled by Honeywell thermostats, control panel and baffles. The house is new to us and I suspect, based on the air flow from the vents, that the baffles don't function properly.
So far I have reset the system and verified that the electronics work and the motors turn when the zones are activated. I've read that Honeywell systems are spring closed and motor opened. My suspicion is that even though the motor turns, the baffles do not open, probably due to broken linkage.
My next step is to take out the baffles, cover the duct hole and then operate the baffles when I can visually inspect their function.
Does this make sense?
