Originally Posted By: CELICA_XX
Originally Posted By: sayjac
First you do some d&f's using distilled till it runs relatively clear. Then you will add the Toyota pink, run it to mix. Then you will have to drain and fill again with pink.
You will need to repeat process until you get to ~50% concentration as measured by a tester.
This might work, but you would be wasting an awful lot of Pink coolant !!
I can attest that it did/does work. In the 01 Civic is took me less than two jugs of Type2, ~1.5-1.75 gals iirc. Got it ~50% concentration using AF tester. But the Civic has relatively small cooling system capacity. Yes wasteful no doubt but it was best option for me at the time.
Honda also recommends 3x d&f ATF trans service, that could be considered wasteful too. Only done single d&f's 25-30k miles.
This is why and when PepBoys OEM brand Asian PHOAT concentrate makes sense. Even comes in matching pink tint.
I just found it and that looks perfect!
Thank you.
I wonder if it's any good ?
It's made by
Recochem which seems to be a reputable company. I'd use it.
That said, last time I did a complete distilled flush on my 01 Tacoma I used full strength Peak Global Lifetime from Napa, working fine, original radiator. PB OEM Brand AF wasn't on the market at that time.
Think I'd give the latter a try now, but PGL won't need servicing for some time to come.
