Good morning,
Let me start by saying, I did some searching here, did some research, even toyed around with A.I. for a while.
Until recently, Subaru Super Coolant came in white jugs, and recently the jugs are now black. The listed formula has changed along with the new bottles:
WHITE GALLON SUPER COOLANT:
water, Ethlene glycol, diethylene glycol, bitterant and “proprietary inhibitors”
BLACK GALLON SUPER COOLANT:
water, Ethlene glycol, diethylene glycol, 2-ethyl hexanoic acid, bitterant and “proprietary inhibitors”
They also sell concentrate by the quart, but call it “extreme cold weather” Super Coolant. Ingredients match the older formula, despite a different name.
ZEREX Asian Blue has ingredients that closely match the original white bottle formula.
I have a 2024 Outback that needs its first coolant top-off. Help me BITOG, you're my only hope.
Are all of the listed coolants the same **** thing? Why the addition of 2-ethyl hexanoic acid?
I went to my only local dealer and they are sold out of the gallon 50/50 mix, and gave ne a complimentary “extreme cold weather” concentrate quart as a “sorry”.
I cannot deal with this long term. Can I make a 2 quart 50/50 distilled water mix with this “extreme cold” version - is it actually the same as the normal concentrate?
Ideally, I would like to just start using the ZEREX Asian Blue, and forget this entire headache.
Can someone help me sort this confusion?
Thank you!
Thank you!
