YouTube UOA Testing of Amsoil SS vs Penzoil Ultra Platinum on Ram 2500 w/6.4L HEMI
Central Texas
This YouTuber started UOA testing using the OEM fill using PUP 0W-40. After several OCIs, did a flush interval with Amsoil SS 0W-40, then sent the next two samples for UOA. He then did a flush interval using the PUP, and sent the next sample for UOA testing. He has LSJr on his channel discussing the results, but you can take a quick look at the UOA results and see which oil is better for his engine and how he uses it. The discussion goes into details on why the results may be as they are on his HEMI engine,
It makes me question whether I should have stuck with the Honda OEM oil for more UOA data points before switching so quickly to Amsoil SS. I might have gone back to the OEM oil for more testing, but I have four cases of HPL PPPCMO waiting to be switched from the Amsoil after this OCI.
So all the wear metals are within a couple ppm of each other except copper. Is it possible the high solvency esters in Amsoil are reacting with copper or cleaning?
I’m not sure we have enough data to determine a trend with one oil or another.
The copper would react with the ester base in Amsoil.
Did he explain the viscosity of the Amsoil? Seems like a lab error. I've never seen Amsoil 0w40 end up as a 8.8. And fuel is only 1.1% so it's not the oil.
The reaction between the esters and copper was was his hypothesis, also. He said the HEMI engines typically have high copper levels compared to others and might have something to do with copper used is VVT (or something else, which I don't remember), but doesn't seem to effect the longevity of the engines.
Didn't mention viscosity discrepancies. I'm on my small MacBook at the moment and can't see details very clearly. Thank you @rijndael for capturing and posting the results. At least now I can see it.
I cannot stress this enough ....
Singular UOAs (and small sample sets) are NOT, IN ANY WAY, a means of comparing/contrasting anything. To make any conclusions of the superiority of lubes based on a couple of UOAs is foolish. Doing a few "flush runs" may help normalize the chemistry in the sump by reducing residual oil from a previous run, but it does not present enough data to understand "normal" (statistically reliable) performance.
The comments LSJr. makes leads one to believe that these are logical conclusions. Nothing could be further from the truth. He may be a trained tribologist (debatable), but he is most certainly ignorant when it comes to the world of proper data-driven analysis.
I'm disappointed that vehicle mileage isn't on the report, unless I'm missing it somewhere, it looks to be just service interval mileage. I'm assuming by the OP that this is a brand new engine. If so, why in the world are we starting to compare wear metals when the engine isn't even wore in yet?
I offer up my truck with a similar engine as some information. Full disclosure, it's a highway queen that will haul junk to the dump or a few thousand pound trailer periodically. It's the family hauler for our family of five on the daily, road trips, etc. With the exception of the 5/10/24 UOA, I run a flush interval before sampling, I was just too curious to not do a UOA at that time.
This is the second OCI of switching back to HPLs standard Passenger Car Engine Oil. These two OCIs were with 5w30 instead of the 5w20 that I used in 2023. I've owned the truck since 8800 miles and have followed the OLM with synthetics since then.
I'm really liking this report with a couple of asterisks. I asked for GC specifically, provided them starting oxidation so the only thing flagged was water but it was flagged green. Filter is a Carquest Premium Blue.
Iron as mellowed out nicely and does coincide with the HPL switch, which is interesting. Copper has mellowed as well. Aluminum is consistent.
My intention is to change the filter, top off and take this to 15,000 miles. Not sure if I'll sample and change, or sample and run it to 20k accordingly.
Fuel dilution and water. Never had water registered on a UOA before. The sample was taken after driving home from work, so it was fully hot. It sat for 10 min or so before I drew the sample through the dipstick tube. I know the weather was stupid humid and it was starting to rain. I thought I took care in that fact, but maybe I didn't. I drew the sample, capped the bottle and put it in the truck. Is it possible this is just condensation from the weather and heat of the oil?
Last GC fuel reading was .6 % so it's definitely higher than that reading. My idle hours are up a bit for this CI Is this even something to think about or just take another sample at the oil change and see what it is and go from there?
HPL PCEO 5w30 VOA - Baseline oxidation 33.7
Date6/5/224/8/2312/2/235/10/248/18/247/8/25
LabBlackstoneOil AnalyzersOil AnalyzersOil AnalyzersOil AnalyzersOil Analyzers
Vehicle Mileage3653556305761618709795258117486
Oil Mileage10073979797091093681618641
Changed?YYYYNN
Make Up Oil0 qt0 qt0 qt0 qt0 qt0 qt
Oil Brand/GradePenn Plat 5w20Penn Plat 5w20HPL PCEO 5w20HPL Euro 5w30HPL Euro 5w30HPL PCEO 5w30
504/507 Formula504/507 Formula
Iron (PPM/1000)24 (2.4)34 (3.5)16 (1.6)18 (1.7)14 (1.7)15 (1.8)
Chromium111111
Nickel010010
Aluminum (PPM/1000)3 (.3)5 (.5)5 (.5)5 (.5)4 (.5)5 (.6)
Copper (PPM/1000)42 (4.2)22 (2.2)29 (3.0)42 (3.9)37 (4.5)21 (2.6)
Lead000210
Tin000000
Cadmium000000
Silver000000
Vanadium000000
Silicon78169715
Sodium750645
Potassium221041
Titanium101001
Molybdenum62516199727586
AntimonyN/R01010
Manganese212111
LithiumN/R00001
Boron22211831826
Magnesium492414210211208982129
Calcium9189031193158916481114
Barium000000
Phosphorus565589712706683739
Zinc622684877836795816
Fuel Dilution %<.5.6 - GC<1<1<11.2 - GC
Soot %N/R<.1<.1<.1<.1<.1
Water %0<.1<.1<.1<.1.1 - Hot Plate
Viscosity 100*C8.728.89.412.312.610.4
TBN2.51.916.654.465.32
8.49​
OxidationN/R1234353636
NitrationN/R1118161618
I can't imagine picking the "best oil" for my engine based on a YouTube video.
But that may just be me.
That's messed up.
I'm not watching a 39 minute video. What was Lspeed's conclusion?
I really want to know how you can see this.
Redline and HPL also see high spikes in copper the first time they're used in a ram/hemi, subsequent runs always end up with lower amounts.
That's messed up.
They 100% botched the viscosity on the Amsoil somehow. Speed does use different equipment that measures metals differently, but this viscosity is clearly an error.
So you guys are asserting that maybe 10 or 20 oil cycles on each oil would be needed to get a clear picture of how the engine reacts to each?
I'm not a tribologist, but I did stay at a Holiday Inn Express last night, (and I have a science background with statistics and data analysis in my transcript) and I strongly disagree.
Seems SD reports have more and more errors and is why I'm switching to WearCheck.
In another thread you said you weren't going to do any more particle counts with SD since they always seem to have the exact same ISO codes. Just FYI, WearCheck seems to do a good job with particle counts.
