And doesn't heat cause varnish?Oil gets darker with heat.
It can.And doesn't heat cause varnish?
Yep that's my philosophy as well. Don't like changing in the rain or the freezing snow. So its early October and April. Its worked very well for over 20 plus years.My S10 with a 4.3 has around 130,000 miles on it, and I change the oil every 5,000 miles or 6 months no matter what the mileage is when 6 months comes it is getting changed, sometimes I am lucky to get even 1500 miles on an oil change on this truck. But the engine is very clean inside and very smooth no indication these shorter intervals are causing additional wear.
Same reason diesel engine oil is black in no time, blowby.Then what exactly is the stuff in the oil circulating around the engine that is making it dark? Fairy dust? Anything in the oil besides the oil itself is adding some internal wear. Small maybe but something none the less.
Time to stir the pot and poke the bear. The "increased wear with too frequent changes" probably comes from the 2007 Ford study: https://www.sae.org/publications/technical-papers/content/2007-01-4133/ , discussed ad nauseam on the interweb.
Hey did you know...oh sorry.I suspect the extreme oil change crowd are not using 502-504 oils and especially the more expensive and harder to find 504 spec. ( M1 exception noted)
Those 3k changes could get expensive... Let's not rehearse the FCP Euro return policy![]()
I have to read how you kindly go into excruciating detail to educate those unaware. Very kind of you as I myself suffer burnout from regurgitating info like this. Kudos to youHey did you know...oh sorry.
?The ones that are still around have their own problems?
GM has AFM problems and Mopar has Hemi problems
Oh. I thought you were referring to old push rod engines like I have.GM has AFM problems and Mopar has Hemi problems
This all depends on your engine and driving conditions.Changing your oil prior to 5,000 miles is a "money flush". And one could argue even that interval is a "money flush".
By any chance, is this idea floated around by CAFE organization?Apparently there's an idea floating around out there now that frequent OCIs can contribute to engine wear due to the additive package not being allowed to dissolve or break down sufficiently
Not sure, quite possibly.By any chance, is this idea floated around by CAFE organization?
5 vehicles? But why?I maintain 5 vehicles within my family. No one gets an oil change before 12K, I'm not doing 20 oil changes/year, I have a life. I'm running Amsoil SS, which many refer to as a "boutique" oil, I prefer to call it good. I do UOA and have a history of somewhere between 46-50 oil reports, so if anyone wishes to accuse me of "abusing or neglecting" my vehicles, take it up with Horizon testing.
You are free to change oil as often as you like; I'm not the one crawling under your car(s).![]()
