- Joined
- Dec 28, 2014
- Messages
- 3,001
The thought process behind this is that the first 3,000 miles of an oil change is where the most wear occurs during an interval (because of the additives), so in theory if you change the oil every 3,000 miles you are always subjecting your engine to that wear. I don’t know if I buy this or not, but the theory is if you can go to say 5,000-7,000, or whatever, you’ll have a good 2,000-4,000 miles of less wear on your engine internals. And the filter will also become more efficient in that range. It was an SAE article/study. I think more information, study, clarification, common sense, is also needed. Doesn’t matter to me, I change my oil every 5,000-7,500 miles anyway. Sometimes even 10,000, but I have an engine that is not direct injected, no turbo, easy on oil (historically, with UOA’s to back that up). And no oil usage between intervals.You Can't Change Your Oil Too Much!
Or at least this was the conventional wisdom when I was a kid back in the 70s. I have followed this for all of my adult life and I can say that it has always worked for me.
If a vehicle's recommended OCI was 4k miles, i would almost always change it before 3k. If oil was on sale and I was doing one vehicle, I would sometimes change multiple vehicles just to take advantage of the sale.
These days it's not unusual to see recommended OCIs of 8k or 10k miles... I have a hard time believing that oil and engines have improved that much.
Apparently there's an idea floating around out there now that frequent OCIs can contribute to engine wear due to the additive package not being allowed to dissolve or break down sufficiently.
With racing machines, it's fairly common to change the oil after every race. However racing vehicles aren't intended for longevity, the goal is speed.
So is it still true? Is it possible to change your oil too often? Or is this marketing malarkey from engine manufacturers?
Or both?!
