I read that many oils sheared to lower viscosity readily, however I am unclear what caused the oil shear and what oil properties diminishing beside the viscosity when it shears ?
The reason I ask is it seems many xw-30 GF-5 oil often makes engine sounds louder, so i am wondering if using xw-40 that shears readily will be better to achieve muted engine noise and compensate the power loss due to thicker oil compared with xw-30 oil ?
Please advise.
Thank you.
Please advise.
Thank you.
