For xW-30, what would x have to be if the oil was to have a similar viscosity at 20F as SAE 30 does at 212F?
My 72 Pinzgauer manual says it is supposed to use SAE 30 in the summer and SAE10 in winter. I do not believe they had multigrade oil when it was built. I want to use the same multigrade year round. My oil temperature is a bit above 200F after warm up and my coldest mornings are around 20F.My guess is that the viscosity of SAE 30 at 212 F degrees is probably the ideal viscosity because that was what the manufacturer speced when they did not have to worry about cold weather starting. But what would x have to be if the oil was to have a similar viscosity at 20F as SAE 30 does at 212F?
