Search on this oil spec returns N0 BOB hits.
F150, 2014 3.7L *New to me*. Ford manual states XO-5W20-QSP or XO5W20-QFS (U.S.); CXO5W20-LSP12 or CXO5W20-LFS12, 5w-30. I cain't find this except for MOPAR, which is 7 dollars a jug more than SuperTech.
1. Is there more certification documentation available for National Brand Oils?
2. My Prius specifies : ILSAC GF-5. SuperTech exceeds. Hooray.
3. I use SuperTech for everything...........
4. ADVISE............
WOOPS........MY MANUAL FOOTNOTES THIS)))))))) SORRY....MY QUESTION ANSWERED IN MANUAL..........
The design of your engine allows for the use of Motorcraft engine oils or equivalent oils that meet Ford specifications. It is also acceptable to use an engine oil of recommended viscosity grade that meets API SN requirements and displays the API certification mark for gasoline engines. 3
Do not use supplemental engine oil additives in your engine. They are unnecessary and could lead to engine damage not covered by your Ford warranty.
Do not use API S category oils labeled as SN, SM, SL or lower category unless the label also displays the API certification mark. These oils do not meet the requirements of the engine and emission system.
