My great aunt is selling her '03 Grand Marquis with 105k miles. The car is in great shape minus a bit of a transmission issue. To my knowledge this is a 4R70W (LS Ultimate Edition, shifter on steering column, all digital cluster, no tachometer). My sister is in need of a different car. Her '99 Accord 2.3L has 235k on it (engine and trans are good
, everything else not so much).
Symptoms:
The trans has issues no matter what the temperature, but worse when hot. When I apply virtually no throttle (maintaining an exact speed, say 40mph), there are no problems. When I apply more than ~40% throttle there are no issues. But anywhere between those two ranges (light-normal throttle) the transmission seems to be problematic. 3rd gear seems to be the worst (35-50mph), and the 3-4 shift is sloppy. When shifting between 3-4, it seems to shudder (feels like running over the rumble strips on the shoulder of a highway, but much less severe) as well as hunt for what gear it wants (3rd? 4th? 3rd? No, 4th...). There is NO shudder from a stop. Reverse is fine. No SES/CEL light, no O/D light flashing (I read this is an indicator of a problem on the Marquis).
History:
Pretty much unknown. My aunt can't recall ever servicing the trans
. She is the second owner and had it much longer than the first. What is strange is that the trans fluid does not appear to have 105k on it. It looks like it has 30k on it, maybe 50k at most. It is very red, but definitely hasn't been changed recently. There is some dark stuff in the fluid, nothing scary, and nothing metallic. When wiped on a paper towel it appears very dark, but when held up to sunlight, it is very light. The fluid level is good, if anything it is a tiny bit over the full line. No foaming.
So all that being said, my questions are:
1. What could the transmission issue be?
2. Should my sister purchase this car or look elsewhere?
3. If she does buy it, I will be doing all the maintenance, so what should I do to cure the trans?
Symptoms:
History:
