My wife's 2013 Escape (2.0 turbo, 6F35 transmission, FWD, bought with 59,000mi - current mileage, 93,000) is showing some issues. I was driving her to work, and while accelerating to get on the highway, the engine hit 4k rpms during acceleration, but then didn't upshift when I let off the gas. It hung at 4k for a few minutes, eventually shifting and the rpms went to normal (2 - 2.5k). It also had what initially seemed like a low rpm engine shudder upon acceleration after getting gas (it wouldn't shudder in neutral though).
I broused YouTube and found that the 6F35 needs regular fluid changes, and I had no idea if or when the fluid had been changed, so I did it myself using Valvoline Extended Performance ATF, following all the recommendations from the how-to videos.
Initially, the light shudder seemed to have lessened, and was slightly more spread out in the RPM range. After ~1,000 miles, it SEEMED much smoother, but it suddenly started shuddering worse, making noise and there is a definite "grinding" feel to the gas pedal. It became so obvious, that even my wife started to notice.
I'm going to take her to work today, so I can get underneath and double check the fluid level (....'sealed, non-serviceable transmissions'), but if that checks ok, then I only have 2k miles to get it to the dealer (our extended warranty expires @ 95k).
I take her to work @7am, so I should be crawling under the car by 8am - anything else you guys think I should look at before I call the 'Stealership?'
