Here is a link that may be helpful....
http://www.1945gpw.com/c-3-G503_WWII_Jeep_Go_Devil_Engine_Change_Oil.aspx
Note: The author says this engine uses 30wt and he uses a 10W30. Which would appear acceptable. Heavier grades will make it very hard to start in the winter months. And, heavier grades really aren't necessary. Nor is a synthetic. I'd use a 10W30 SM rated conventional or syn blend, like Motorcraft (or one of the Conoco-Phillps clones)which would be a good compromise). The Go Devil is a low output engine... IMHO, synthetic would be way over the top.
Not having seen one of these in awhile, I think they are 4 qts plus a quart for the filter ... give or take.
I'd skip all the 'cleaners' and 'flushers' since this engine is probably going to get frequent oil changes. Just change the filter at the same time as the oil change.
Here's something that might be interesting...
See pp 138... http://books.google.com/books?id=K5-_RMz...;q=&f=false
