1. Can air get into Auto A/C systems ?
I understand that the A/C system is under higher pressure (than the outside air) the R134A gas inside would be pushing outwards. How then can the A/C system allow the air to enter if the air outside the A/C system is at a lower pressure ?
2. Possible cure for minor R134A gas leaks.
Any BITOG's used this product, Looks the real deal, check the link
http://www.wurth.com.au/catalogue/A04_0604.pdf
This is the same product marketed worldwide by Wurth's.
Claims it has no polymers wont gel, hardened or clog A/C systems or any A/C recovery equipment.
I understand most Professionals warn not to use any stop leak in A/C systems, Is this one different ?
It is around $100. AUD. I am tempted to give it a go as a top up.
