If you had a car and were seeking to clean up the Rings, would you:
1) Use ARX with SuperTech, plain old Oil, 3 oc a Quart, for 3000 miles, maybe change filter mid-way, then run that same ST for 3000 miles, then use your Oil?
2) Just use Pennzoil Platinum? or
3) Some other route? (MMO, etc. ARX seems to be better?) .........
ARX seems tempting for cleaning Piston Rings and Ring packs. ST or Delo 400 can be used, if i read it right. People report great results, and even suggest taking the OCI to 5000 miles for best results in Initial and Rinse phase - add to hot engine, let idle 5 minutes, complete OCI. It also costs a lot.
Some people swear by PP. Leak-causing is my concern, unless PP generally does not do that.
And, i was going to use either PP or Castrol Syntec after ARX. If no leaks develop, i dont need a High Mileage oil, or even Seal Conditioners, as ARX will hopefully have cleaned it all up.
Thoughts?
Cleaning up Piston Rings seems like a good place to start, in the road to my car's Oil.
Thoughts?
