OVERKILL
$100 Site Donor 2021
BTW, 5,650cP is heavier than 5,553cP (the 0W-30), so I'm not sure what the point of that screenshot was
Try again, the post right above this one of yours proves the CCS of HPL 0w30 is lower than the Castrol 0w20. However, you clearly don’t understand the distinction between cold cranking simulator and pumpability. As was noted earlier, if an oil is pumping, it is protecting, even if it’s thick.Go look at the -35 css for both oils......
It should become clear
Yeah, it's clear that the the two 0W oils (one a 0W-20 and one a 0W-30) @OVERKILL posted a few posts above makes it clear that both 0W are essentially the same CCS viscosity at -35C.Go look at the -35 css for both oils......
I'm thinking there isn't quite a fully understanding that the "W" (0W, 5W, 10W, etc) grade is a whole different and separate viscosity measurement than the "20" or "30" KV100 viscosity. There are probably even 0W-40 oils out there that have very similar "W" grade CCS viscosity as the 0W-20 and 0W-30 oils.However, you clearly don’t understand the distinction between cold cranking simulator and pumpability. As was noted earlier, if an oil is pumping, it is protecting, even if it’s thick.
Ask and you shall receive:I'm thinking there isn't quite a fully understanding that the "W" (0W, 5W, 10W, etc) grade is a whole different and separate viscosity measurement than the "20" or "30" KV100 viscosity. There are probably even 0W-40 oils out there that have very similar "W" grade CCS viscosity as the 0W-20 and 0W-30 oils.
Yea but what happens when those coatings wear off? And they do.Well, new engines specifying 8, 12, 16 grades are specifically designed to be able to withstand those viscosities. Sputter coated bearings, wider journals, piston skirt coatings, DLC cams, etc. I would say it is science being used to solve a problem that you may not agree is a worthy goal. We've already come to some point of compromise, it's just shifting. If not we'd all have been running 5W-50 or 10W-60 for the past 2 decades.
It might be right there - - - but it IS LOWER when comparing name brand synthetics - - - -not some expensive boutique oil that only .0000001% of the driving public uses.View attachment 189478
^^^ What does that prove? The CCS viscosity is pretty much right in there with the other 0Ws posted.
Pumpability is a binary and is illustrated by the winter rating. If it pumps, it will pump. A thicker oil will take an incrementally higher amount of energy to pump but even then it is transitory since the oil heats up rather quickly. And the thicker the oil is the faster it will heat.Anyway - - - - Im done providing evidence in this thread and betting bashed for it.
If you think a thicker oil will pump better in the same temp as a thinner oil - - cool.
Take castrol for example
0w-30 https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/87060D27348C7F4F80257D47004FB66D/$File/PDS CCSA Castrol EDGE w FST 0W-30 english.pdf
0w20
https://msdspds.castrol.com/bpglis/...305276F8025808B0047EB89/$File/BPXE-AHH32P.pdf
The 20 weight is lower at -35 vs the 30 - - - - - not by much but it is lower - - where it diverges is the -40 temp.
Here are your Castrol examples, specs shown below from the spec sheets. Actually, the 0W-30 has a hair lower CCS viscosity at -35C. They are both almost identical 0W rated CCS viscosity. Both will pump essentially the same because one is 5897 cP (the 0W-20) and the other is 5800 cP (the 0W-30) at -35C. There is no evidence seen here that one is better than the other, or even better than any other 0W spec sheet posted previously. In fact, the two Castrol Edge oils you linked both have thicker CCS @ -35C than all the other previous 0W grade oil's posted previously in this thread.It might be right there - - - but it IS LOWER when comparing name brand synthetics - - - -not some expensive boutique oil that only .0000001% of the driving public uses.
0w20
They should be designed to last the life of the part. I mean, take the bearings for example. People have torn down BMW B58 with 100k miles and the IROX coating is still looking like day 1 on the rod bearings. I’m not as familiar with the various piston skirt and cam coatings etc but I would say any coating failure is a design flaw. Every part has a MTBF target, coated or not the OEM expects x miles out of a part. Would you use these coatings in a million mile design? Maybe not, but we’ve seen enough bad cam surfaces, bearings, etc. before the coatings became popular already. Everything is a wear item given enough time.Yea but what happens when those coatings wear off? And they do.
FYI Honda CR-V -- in Japan the owner's manuals list an acceptable oil weight range of 0W/20 through 5W/30Okay Folks, I have searched all over, and I didn't see this specific question addressed. (and forgive me for having already sort of explored this question in another person's posted question regarding mixing of the two grades.)
My 2019 Equinox (1.5L turbo engine) specs 0W20 oil. I really believe that 0W30 would be a better choice.
After way too many days of researching all over the 'ole interweb, I have concluded that 0W30 will afford better engine wear protection at normal engine operating temperatures.
Both of them have a "Winter" rating of "0", so until the engine reaches it's normal operating temperature both oil grades are essentially identical. However after the engine reaches normal operating temperature the pictures is quite different. The hot viscosity (100 degrees C) for the 0W20 is between 5.6 and 9.3 centistokes, and the 0W30 is between 9.3 and 12.5. And from all the research I've done, it appears that from a mechanical engineering standpoint, motor oil viscosity of about 10 or 11 cSt is ideal for the vast majority of automotive engines. -for at least the last 40 or 50 years.
For the American auto engines, 10W30 was pretty much the standard from about the 1970's through the 1990's, and then around 2000 5W30 became the norm. But now with the government fuel economy standards squeezing blood out of the industry and engine displacements getting very much smaller (and hopefully with more precisely controlled tolerances) the 0Wxx oils are apparently the new normal.
I find this fact quite interesting: When GM starting using these 1.5L turbo engines in 2016 the oil spec was 5W30. It seems to have magically changed to 0W20 in 2018. I have researched OEM GM part numbers for many of the internal engine parts used in these engines, especially the parts where oil clearances are critical. And from 2016 through at least 2019 the part numbers are identical. Looks to me like the popular reason/excuse given for switching from 30 weight hot to 20 weight being because of so-called tighter tolerances is -V--E--R--Y- questionable. How about this reason: C.A.F.E standards. -all striving for potential fractional increases in mpg.
Until I am shown differently, I am convinced that use of 0W20 is risking long-term engine wear protection.
Certainly, the cold temperature qualities of the the 0Wxx is no doubt a very good thing . On "cold start" the less viscous oil should reach the critical lubricated parts faster, and certainly have much better lubricating qualities than an oil that is way too thick. And granted, it is common knowledge that the majority of engine wear occurs at startup. But the actual wear protection value due to the very low viscosity value of a 20 weight oil when hot,,,, very questionable I'd say.
Maybe more wear hot, but less wear cold will balance out?? I suspect with 0W30 we can have less wear in total.
So, back to my opening question, given the facts before us, would you consider using 0W30 instead of 0W20?
Thanks to everyone reading this !! Looking forward to your comments.
And Japan has their own kind of "EPA/CAFE" thing going on and they still allow a range of viscosity.FYI Honda CR-V -- in Japan the owner's manuals list an acceptable oil weight range of 0W/20 through 5W/30
Done a few myself.Seen worse Necroposts.![]()
