Would you change out this oil?
Originally Posted By: ueberooo
Thin it out with some MMO if you have room to add some. I'd keep it a tad longer for another few tanks of gas but change it before 4k mi.
The OP is in Alberta. Mmo is unavailable in this country,and if it is I've never seen it. I've had to order mmo from the free nation south of us.
So the mmo idea likely isn't an option.
Why add mmo anyways? The oil is fine the way it is,unless the op is trying to clean something?
I don't believe in oil additives.
The oil will be fine for 5000 miles. Just run it on the highway for a while now and then to be sure any fuel/moisture from condensation is burnt off.
Originally Posted By: KevGuy
Last October I dumped the Quaker State Conventional 5w20 from my 2008 Ford Edge and put in Pennzoil Platinum 5W-20. The oil now has 5000 km (3100 miles) on it. Furthermore, the winter here has been very brutal so far and my vehicle has seen quite a few -35 C (-31 F) cold starts. I have been thinking about dumping this oil on the next fine day and putting in Quaker State Ultimate Durability 5W-20 for the remaining of the winter. Should I just leave it for another 2000 km or change it?
Leave it in, the oil will be fine - but change the filter to a Purolator or Wix ASAP.
edit - I saw you're running a Mobil 1 filter. Good job buddy!
Yeah, I knew that I would probably be running this PP oil on an extended drain interval, so I didn't put on another orange can as I don't think they are viable for 7500 km OCI. In the spring when I go back to Quaker State Conventional, I'll probably just use orange cans again.
I filled up today and while doing so I checked the oil. The oil is still up to the full level but is starting to turn a bit black, and had a tinge of that "used oil" smell to it, but you can still see the golden colour to it. I'll run it another 1000 km and see how things look then.
