This was only one test for each filter, random sample lots would need to be tested to see if these results are typical for each type. Statistically speaking this is insignificant. I cannot say which is best, only present this small set of data and let you decide what it means.Again which filter would make my engine last the longest in real life application.
Engine wear vs oil cleanliness studys always conclude that cleaner oil results in less engine wear. So it shouldn't be hard to connect the next dot.Again which filter would make my engine last the longest in real life application.
Any idea how much actual GPM that oil pump puts out at 6000 RPM? Looking at the delta-p vs flow curves, the Ultra was in the good flowing filter group. The fluid Andrew used for the delta-p vs flow testing was about the same hot viscosity as xW-40 weight oil - it was mentioned earlier in this thread.@ZeeOSix Can I run an ultra with 5w-50 @ 6000 rpm 650HP standard oil pump?
But I have seen for years vehicles running great with 350,000 miles running Jiffy lube oils and filters. My experience doing fleet work quality oil and what ever filter the parts guy gave us had the engines lasting way too long , My neighbor a very smart guy,, a retired surgeon wanted to buy a hay rake for his hay field and he did lots of research and told me about a rake which worked real good but the articles he read said it was rough on Alfalfa and would potentially cause leave loss from the violent action of the rake. I had to tell him you don't have Alfalfa on your field.Engine wear vs oil cleanliness studys always conclude that cleaner oil results in less engine wear. So it shouldn't be hard to connect the next dot.
Engines can still seem to "run great" even with quite a bit of wear on them. Obviously the shorter the OCI, the less filter efficiency matters. If oil was changed every 500-750 miles, you probably wouldn't even need an oil filter on a broken-in engine. But the fact remains, and always will, that the cleaner the oil the less the wear. No study on the subject matter will say otherwise.But I have seen for years vehicles running great with 350,000 miles running Jiffy lube oils and filters. My experience doing fleet work quality oil and what ever filter the parts guy gave us had the engines lasting way too long.
This is a GM study taken from https://www.machinerylubrication.com/Read/30697/choose-oil-filterWhat I am getting at is there are posted million mile Toyota engines and Ford van engines etc ,. and they are not some sub micronic bypass filter equipped nor are they running oil filters other than oem or jiffy lube filters . Looking at the uoa s Most of the super high mile engines we see the uoas on are mostly bought used with high miles. I am positive their owners didn't read the marketing and papers on oil or oil filters. Buying an oil filter to hopefully let you drive you car to the junk yard with a "pristine" engine is the cool thing to do I guess.
I have the capability to run this oil sample/batch particle count test. In fact I can sample online in real time taping into a vehicles oil lines as it is running. However the vehicle must be in my lab to do it, and it would be very expensive for the latter.All this about particles cause wear was deduced long ago. The Frantz oil filter was developed with this in mind and ads from the 60’s and earlier talked about clean oil. They work. Here they took off a full flow filter and in 200 miles the Frantz clean up was amazing.
https://www.frantzfilters.com/science/
That said, I had a few of them. Took them off or left them on the cars when sold or traded. I gave a box full of them to Goodwill in the 90’s. My dad started buying them in the flea market, and I know $5 would have been the limit for him, if that. I have been looking at them again. It’s terrible. Now if I had a Ford diesel, which I used to have the 6.9, I would put a Frantz on it. Thankfully it is now difficult for me to put one on a car, but the Toyota pickup does have the room.
I hope you can do more testing like that as time goes on. Give Blackstone some competition. It's all getting a bit much for me. I was supposed to pull some weeds this morning, but look on the internet instead.I have the capability to run this oil sample/batch particle count test. In fact I can sample online in real time taping into a vehicles oil lines as it is running. However the vehicle must be in my lab to do it, and it would be very expensive for the latter.
I wish they stated the sample/batch volume for the particle count. Then you could calculate total counts in the engine with a little algebra.
A quick note: The particle size is not the same as I have tested here, meaning they used a different calibration method to calibrate there particle counter. 2 micron in the Frantz test is not the same corresponding size in my test. I use the ISO 11171 calibration denoted by um(c), not sure what method they used, but it is not the same.
For example if they calibrated with ISO 4402 (which was common back then) then 2um is equivalent to 4.6 um(c) that I use for the ISO 11171 calibration.
Like said before, it also depends a lot on the OCI. If someone is doing a 3-5K OCI then a high efficiency oil filter isn't as important. For a short OCI, I'd still go for a filter that's at least 90% @20u. The way I see it is why not pay a few bucks more for a high efficiency oil filter that gets changed once a year. One less street taco for lunch over a years time, and it pays for a better oil filter.What I am getting at is there are posted million mile Toyota engines and Ford van engines etc ,. and they are not some sub micronic bypass filter equipped nor are they running oil filters other than oem or jiffy lube filters . Looking at the uoa s Most of the super high mile engines we see the uoas on are mostly bought used with high miles. I am positive their owners didn't read the marketing and papers on oil or oil filters.
As long as I own the vehicle, keeping the engine "pristine" is a goal. If it gets wrecked or sold then it's out of my hands, but I don't treat my vehicles based on looking way into the future and say: "I don't care how I treat or take care of it because someday I won't own it anymore".Buying an oil filter to hopefully let you drive you car to the junk yard with a "pristine" engine is the cool thing to do I guess.
Blackstone uses ISO 4406. It's the number of particles in a mL volume.I wish they stated the sample/batch volume for the particle count. Then you could calculate total counts in the engine with a little algebra.
That study from GM (SAE 881825) is a HALT, and as such, it leads many to conclusions that are not based in real life. It would be VERY useful to anyone whom never changed oil and only used "40um" filters are a baseline. Otherwise, it's grossly misleading to the uninformed. Here are some highlights from the study:This is a GM study taken from https://www.machinerylubrication.com/Read/30697/choose-oil-filter
No test is perfect.That study from GM (SAE 881825) is a HALT, and as such, it leads many to conclusions that are not based in real life. It would be VERY useful to anyone whom never changed oil and only used "40um" filters are a baseline. Otherwise, it's grossly misleading to the uninformed. Here are some highlights from the study:
- they dumped the equivalent of 570k miles of particulate into the sump over the 8 hours of the test (hence - it's a HALT test)
- they never changed oil once - not one time! during each phase of the test; So any particulate matter smaller than the filter rating remained "forever" in the sump for that test cycle (Who does this???? who among us NEVER changes oil in 570k miles ?????????????)
- they only changed filters when the dP across the filter got to 20 psi (this ain't what happens in the real world)
- they used "40um" as the "baseline" (as if any normal engine filter was that porous these days
GM even admitted right in the conclusion statements of the paper that the results from the study would not be replicated in "normal" operation of a vehicle. They knew that to bring the disparity of filtration effects out, they'd have to manipulate the conditions of the study in such an absurd manner that no "normal" maintenance schedule could be followed.
I concur that reducing particulate loading in the sump is a good thing. But there is also a limit where improving the cleanliness does not really generate a decent ROI for efforts. Once a system is "clean enough", making is significantly cleaner really does not do much for you. This is why we see engines with a million miles on them, but only had "normal" filters used.
Much of this misunderstanding comes from the ignorance of many regarding the size of soot early on in it's lifecycle, as well as the relationship of the OCI to the effects of filtration. What the GM filter study showed is that if you intend to never change oil, filtration is very important. What the study did not show is how filtration effects are muted by the duration of normal OCIs.
I loath this study ... not because it's a bad study, but because it's used by marketing folks to hook customers and trick them into thinking that ever more filtration is always necessary for your engine to be safe, and without it your engine is doomed.
The 4406 is for categorizing different cleanliness levels from the reading on the particle counter. Both the 4402, 11171, can both be categorized in counts/mL using each calibration standard. You would get different 4406 results for each (4402, 11171). I know the 4402 is discontinued, but I get sent filter drawings now and then form companies that spec the old 4402 on it :-( it is a tuff conversation.Blackstone uses ISO 4406. It's the number of particles in a mL volume.
https://www.blackstone-labs.com/particle-count-test/
