Maybe not allowed, but I hope you are vaccinated or plan to be. I did it's a great feeling to get it done.In this case efficiency did not get significantly better over time and exhibit that behavior. The "Hockey Stick" is demonstrated in the deltaP Curve vs Time. The Medium Test Dust was injected at approximately 2.1-2.2grams every five minutes for each filter.
It will all be explained in the video.
Very good effort, and considerable expense.
If I read correctly for an 18 gram filter you are adding about 2 grams 9 times over 45 minutes.
I believed youThis is exactly how the "hokey stick" efficiency curve starts out. As the delta-p increases, already captured particles in the media start sloughing off and going down steam which the particle counter sees as worse efficiency. I've posted about this many times, but nobody seems to believe it, lol.
