Unsubstantiated ??? Oil pressure went to nearly ZERO, then within seconds of this happening, my engine spun 3 main bearings and 4 rod bearings. Upon cutting the filter open after engine teardown, the media was a balled up wad of crap that was so wadded up it blocked the bypass valve also, which then led to nearly ZERO oil being circulated through my engine. Just FYI, at 2,500 rpm 3 psi of oil pressure just won't cut it for protection. I can assure you my post was 100% substantiated![]()
One persons description is not exactly “substantiated” evidence. I’ve never heard of any filter doing what you describe.
