Originally Posted By: hate2work
This thread should be re-named "Wix Install Failure".
I'm not sure why everyone is so quick to claim that's the case?
Maybe, but if you read the thread, the guy seemed to do everything correctly. He lubed the base gasket and turned it 1/2 a turn (which is, on most filters, the correct angle torque). Whether or not he used a filter wrench to tighten it means nothing--angle torque is angle torque. And if you read the thread, he simply used the filter wrench for clearance issues.
He was also backing up just to watch and check for leaks, so he was even doing that correctly (not just getting in and driving away). In other words, he seems like a guy who has changed his own oil before, and knows what he's doing...
Maybe he's misremembering--or maybe the gasket was actually defective. Bottom line is that it's a good reminder to always check for leaks after changing your oil.
