WIX 51335
Illinois
Anyone got the good info on this filter? It's short and fat and just the right size for my needs.
Here is what I have:
WIX - Oil Filter
Part Number: 51335
Line: WIX
1 year limited warranty
UPC: 765809513358
Thread Size: 3/4-16 Inch
Top Outside Diameter (In): 3.670 Inch
Bottom Outside Diameter (In): 3.670 Inch
Height (In): 2.483 Inch
Anti-Drainback Valve Included: Yes
Additional Details
Gasket Inside Diameter (In): 2.462 Inch
Top Inside Diameter (In): Closed
Burst Pressure (psi): 280 psi
Bypass Valve Included: Yes
Bypass Valve Pressure (psi): 8 To 11 psi
Flow Rate (gpm): 7 To 9 gpm
Gasket Outside Diameter (In): 2.834 Inch
Gasket Thickness (In): 0.255 Inch
Media: Paper
Micron Rating: 21 Micron
I'm more interested in the filtering media if anyone has seen the innards. There also is a Baldwin the is close to the same size. B7221
Its about the same diameter as a 51085 and is about 1.5" shorter.
Anybody know the media area of a 51085?
I'm just glad I found a short filter with the 3/4-16 threads so I can use it on the Ford filter mount oil cooler that I have installed on my Hyundai.
And it is short enough I can still add my sandwich gauge port adapter that is 20mm thick and have more clearance than I have now.
Currently I run a remote filter and the oil line fittings are below the oil pan level.
I installed one of these on the OEM filter mount.
