I was wondering if anyone knew of a filter that has better media/higher rating than wix #51453
App is the spin-on hydrualic filter for a IH Hydro 70 w/ D312 diesel.
Just wondering if there is a "better" filter out there.
Part Number: 51453
UPC Number: 765809514539
Principal Application: Case Combines, Tractors; Ford, IHC & M-F Tractors
All Applications
Style: Spin-On Hydraulic Filter
Service: Hydraulic
Type: Full Flow
Media: Paper
Height: 5.157
Outer Diameter Top: 3.670
Outer Diameter Bottom: Closed
Thread Size: 1-12
By-Pass Valve Setting-PSI: 7-9
Beta Ratio: 2/20=24/44
Burst Pressure-PSI: 300
Max Flow Rate: 12-16 GPM
Nominal Micron Rating: 35
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.729 2.415 0.255
Part Number: 51453
All Applications
Service: Hydraulic
Type: Full Flow
Media: Paper
Height: 5.157
Thread Size: 1-12
Gasket Diameters
